I am trying to program the Direct TV remote to change the input on my Sanyo TV. I do not have the original remote that came with the TV. I am hooking up my DVD player to the TV on AV1 and I need to switch the TV to AV1 to watch the DVD player. Can you help me do this?
Thanks
SOURCE: Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
SOURCE: Sanyo DS24205 24" TV input problems
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
SOURCE: DS 27930 remote control
My problem is this TV of ours does not work now so if I cannot get it fixed I guess you can buy our remote control.
Doopey
SOURCE: Changing program source without remote
Do a web search for a replacement remote control. If you got the tv without a remote, then I'm guessing you don't have a manual either. Here's a link to a free downloadable manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e341b6ad1733d53ba32cb47caf24d013&q=Sanyo+DS19330
SOURCE: DS24205 TV INPUT PROBLEM
You can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
