Replaced water heater and several broken water lines after freezing temps broke pipes. After replacement, shower clogged and is producing very little pressure. How do I clear shower lines without ripping into walls to expose them?
SOURCE: Fluctuating water temperature in new Price-Pfister Treviso shower
hi there! there is a technical problem in concern with that for sure...try checking the handle it might be loose already. things like that do happened all the time. thanks, kindly rate.
SOURCE: swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
SOURCE: Is the price pfister 016-HH7C shower head any good
I have had good luck with price phister brands, they are as good as any, and they stand behind them. Water pressure is variable depending on where you live, If you live in San Diego, you have great pressure, If you live in Old Town, FL, you have pump pressure. The faucets can be hacked into for more water, but not necessarily more pressure. If you have good pressure now, you can expect the same. Hope this helps.
SOURCE: Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
SOURCE: Our shower head is very similar to the Price
The simple method is to take the faucet head off the extension pipe that comes out of the wall. It will take two pair of pliers and a firm grip to take it off. Using a wet/dry shop vac at the supply end and a garden hose at the shower end, force water backwards through the faucet head.
Testimonial: "Thank you! We are in WI so we will have to wait a bit to try this...but we'll let you know when we get a warm spell."
