I have had my fryer longer than a year so I know it is out of warrenty. Yesterday, cooking oil leaked out of the bottom while the fryer was in use. I emptied the fryer and made sure it was clean. I usually do this about every 3rd time I use the fryer. I can not find anywhere that appears cracked or broken. When I removed the bottom plate you can see where oil has leaked. What could have caused this?
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
SOURCE: How do I remove the portion that holds the oil to clean?
If I remember correctly, the manual that came with mine said that it is not removable. Pour out the oil and wipe the interior with a paper towel. (I wish it were removable!)
SOURCE: how do i get a replacement deep fryer
http://www.rivalproducts.com/help.aspx?helpNav=1
Warranty Coverage
Limited 1 Year Warranty
Rival warrants this product to be free from defects in materials or workmanship for one (1) year from date of original purchase. If you have a claim under this warranty please follow these procedures
To obtain warranty services write to:
Jarden, Direct to Consumer
303 Nelson Ave
Attn: RETURNS
Neosho, Mo 64850
Proof of purchase is required when requesting warranty service – SAVE YOUR SALES RECEIPT. This warranty is extended only to the original purchaser and does not apply to commercial use, unreasonable use, or to damage to the product (no resulting from defect or malfunction) while in the possession of the consumer. Rival disclaims all responsibility for consequential, incidental, or commercial losses caused by the use of this product. Some states do not allow this exclusion or limitation of incidental or consequential losses, so the foregoing disclaimer may not apply to you. This warranty gives you specific legal rights, and you may also have other legal rights which vary from state to state.
SOURCE: Can you remove the bucket (part that holds the oil) on a CF153 ?
as Kachbibi1 suggested, I took the deep fryer apart.
I guess ,if you, REALLY wanted to take it out ,you can. I would NOT suggest doing so.
it is connected and bolted to all the wires and coils to heat the fryer.
My thoughts are, clean well, right away! if we take it out to clean, we will have to replace it right away ..
thank you for the suggestion Kachbibi1...trying that helped me know I cant be lazy : )
