Cars are design to run at a higher idle at start up to warm them up quick. There is a sensor that reads water temperature and tells your car's computer how fast to idle. Your RPMs seem slightly high but not out of the norm. Does idle ever drop to around 600/800 after about a minute? If not, your engine temperature sensor maybe defective.
High idle indicates that the engine most likely has a vacuum leak. This could be due to many causes; cracked hose or hoses, bad gaskets..ect. Hard to say exactly without more info, but you can open the hood and inspect the vacuum lines for damage or cracks. It is a 2009, so it probably is not something major.
Hi ..... This sounds as if it's fitted with an automatic choke, as long as the revs drop when it's warm there is nothing to worry about. The indication when these start to go wrong is that the car won't start when cold ................ even then any decent mechanic can fit a normal/manual choke.
