hi...
the reason it shakes violently is because
1)Most noisesfrom a washing machine occur during the spin cycle. If you hear loudthumping during the spin, the load of clothes may have becomeunbalanced. Stop the washer and redistribute the clothes, then re-startit. Repeat these steps if necessary.
or else the other reason may be
2)
If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switchClutch assemblyDrive motor
Selector switch
Ifyour washer has a selector switch on the control panel, make sure thebutton for your selection is pressed all the way in, or set properly.
Clutch assembly
ManyGE®/Hotpoint® washers use a clutch and an automatic shift lever. Thisassembly is quite complicated. If there's a problem with it, youprobably should contact a qualified appliance repair technician.
Drive motor
manywashing machines have multiple-speed drive motors. Though it'suncommon, the drive motor may work fine on one speed but not onanother. If the drive motor has failed on one speed, you need toreplace the entire motor.
On something like this you will need to
remove the washer wrap toinspect the suspension springs & base assembly. Be sure the shippingpins have been removed. The tub should float freely.
I think my solution would have helped you...rate for me if it is been useful.....thank you for using fixya....
The washer appears to have one of the balance springs missing
