Sony Ericsson Xperia Arc S Logo
Anonymous Posted on Feb 09, 2013
My Sony Ericsson Xperia Arc is only vibrating on imcoming calls and messages. I've checked the settings and everything looks in order. I have also powered the phone off and back on to no avail. Ca
Anonymous
Level 1:
Spread the Word:
An expert who has shared 5 answers on their Facebook wall.
New Friend:
  • Contributor 20 Answers
  • Posted on Feb 09, 2013
Anonymous
Contributor
Level 1:
Spread the Word:
New Friend:
Answers
20
Questions
0
Helped
3442
Points
54
Make sure every setting is not on silent.
  • Anonymous Feb 10, 2013
    Thanks aaron but the phone is not on silent.
5 Related Answers
Anonymous
  • Posted on Aug 14, 2010
SOURCE: My Xperia X10 always restart and can't run and open again.
i don't thrust your name you thief:D
no i don't know.. i'm sorry
Anonymous
  • 55 Answers
  • Posted on Nov 18, 2007
SOURCE: Sony Ericsson K750i White Display
try service mode to check it
>*<<*<* (<=left move on stick)
(>=right '' '' '' '''' )
Anonymous
  • 179 Answers
  • Posted on Jul 13, 2010
SOURCE: How to set MP3 as text message tone on Sony
If you want to set an mp3 or "Custom" tone for your "Notifications" you can dowload an app or...
Connect your X10 to your computer. Pull down the usb notification in top left of screen and mount sd card.
Then go into your phone menu via "My Computer" and either go into media/audio/notifications or create the folders yourself. Remember they must be lower case letters.
Then all you have to do is copy your tone into the "notifications" folder disconnect your phone from your pc and go into "Settings" "Sound and Display" "Notification ringtone" and it should now be in your list with the preset standard tones.
Habiba
  • 67 Answers
  • Posted on Oct 13, 2010
SOURCE: what is call barring password
call barring password is used for call barring service. in call barring you can restrict outgoing and incoming calls
Anonymous
  • 147 Answers
  • Posted on Jan 16, 2011
SOURCE: i am trying to put
Contacts, Hit the options key (The one on the left with 4 dots) then Backup, and choose Sim Card
How to turn on sound on xperia arc s
just go to media play put the puse or once rest the u r phone before this u have to backup ur phone andriod backup to sdcard
Yes it is Sony Ericsson xperia arc s. Where to get the code to unlock
Hi, You can get the unlock code for a Sony Ericsson Xperia Arc S from www.onlinegsmunlock.com at affordable cost with easy unlocking guide. Good luck mate.
Cannot receive calls in sleep mode on xperia arc s
This is a software issue.
Please take it to an authorized service center and downgrade the software.
Experia arc will not let me send text messages
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Pin number required to deactivate, call barring on sony ericsson xperia arc
pin =PERSONAL IDENTIFICATION NUMBER which fixya does not have or access to your accounts if bought this new you can try your provider for assistance with proof of ownership --if bought used can try provider
My Sony Ericsson X8 could not vibrates when getting the message?
try to check if the vibrate of your phone is turned on....maybe it's turned off...check the settings... :)
2helpful
I cannot send text messages from my sony ericsson vivaz u5i, but i can recieve text messages, incoming calls and i can make outgoing calls.. what is the factory setting code so i can reset my phone?
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
  2. Hold the Left and right buttons located beneath the display
  3. Press and release the Power button
  4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
The password is user defined, try the second method if you did not set a password.
Good Luck!
How do I video chat on my sony xperia play
Points to note before you start...
You use this APK at your own risk! I recommend you have a backup, or at the very least a strategy to return your device to stock should the unthinkable happen.
I have tested ONLY on the devices listed below! Extra extra caution is suggested if you want to try it on something else!
Your device needs to be rooted in order to run this process.
If your device is Android 2.3.3, only the required files are installed.
If your device is Android 2.3.2, the build.prop is also edited to 'spoof' the newer version.
As part of the install process, your Google accounts will be wiped and you'll need to re-set them up when you reboot.
Devices i've tested this on...
Samsung Galaxy S II (fully working)
Sony Ericsson Xperia Play (fully working)
Sony Ericsson Xperia Arc (rear camera only)
Let me know if you try it on something else and it works!
How to use...
Download the APK linked below (please do not mirror this elsewhere)
Install on your device in the usual way
Run 'Video Talk Installer' from the programs Launcher
Device will reboot
You can now uninstall the app (you only ever need to run it once!)
And here it is...
DOWNLOAD (ROMraid Load Balancing) - MD5: 9f3976b2191d86754d06f45acadf1810
Jun 03, 2011 • Cell Phones
Where is a more detailed user guide for the Xperia Arc?
Though I firmly believe that the best guide is to just USE the device, I do understand not knowing how to do a certain thing and trying to find it in the user's manual.
I've found a copy of the user manual, I'm not quite sure on the detail:
http://www.pdfuu.com/sony-ericsson-xperia-arc-manual-users-operating-and-services-guide.html
Of course you can always go directly to sony for this information as well:
http://www.sony.com
May 11, 2011 • Cell Phones
5helpful
2answers
Internet settings for my sony ericsson xperia x 10 mini
sir please call to the related simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone save the settings and switch off your cellphone and again switch on. then the cellphone connect to the internet...........
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
