SOURCE: Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
SOURCE: i have the Trimatron Dimmer switch to install,
one black from the dimmer to black. the other black from the dimmer connected to red. the green connected to the bare wire.
SOURCE: Trimatron 3 way push on off dimmer switch
One wire is the common and the other two are the travelers.The trick is to find which one is which.... If you can see into the electrical box check to see if one of the red wires and the black wire are from the same cable, if they are then more than likely those two wires are the travelers; you can also look at the other switch and see which two wires are on the brass colored screws, those would also be travelers. The common is usually the wire that is on the black colored screw. Once you figure out which wire is your common, I'm thinking that it is one of your red wires, you would attach that wire to the black wire on the dimmer and the other two wires to the 2 red wires on your dimmer.
SOURCE: Have a Leviton dimmer with red, black and green
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
SOURCE: i have a black wire a white wire and a ground
The red wire is your chase wire and needs to go all the way to the other switch
