Yonanas Maker - Silver/Black Logo
A
Anonymous Posted on Feb 08, 2013
Yonanas Rubber seal sparepart
Buy sparepart
Kenmore front load washer model number 417. It's been smelling after use.
The rubber seal /boot can be replaced If it's really bad but you will need to clean soap dispenser pull it out all the way buy washer magic to clean rubber seal and door also buy afresh put two tables in tub run longest and hottest cycle with extra rinse once cycle finishes than take half bottle of washer magic and pour into soap dispenser run another cycle if still bad do it all again
Where can i buy parts for mag light 3d size flashlight , the parts that i need is a switch and rubber cap .... thanks
Hi and welcome to FixYa, I am Kelly. Please see this link for the parts you need:
http://www.maglite.com/anatomy_spare_D.asp
Rubber cap is item 7 The barrell with switch is item 6. (mouse over the item numbers and the part number is on the right. If you order the barrell with switch you probably do not need the rubber cap.
The phone number contact page is here:
http://www.maglite.com/spareparts.asp
They may be able to tell you a retailer that sells spares close to you. For sure they can get you the parts you need.
Thanks for choosing FixYa,
Kelly
1helpful
Leak in rear lifthatch water leaking into rear storage area. It appears to be getting in under the rubber gasket door seal
Hi this is quite a common problem, you have a couple of options you can either go out and buy a new door rubber seal or if it one of those seals where you can get you hand in between two parts of the seal then what you can do is get some thick string and run this in the middle of the seal doing this will pack the seal out a bit and then when the door is shut this will make a lot better seal and it will then stop the water getting in.
let me know if you need further assistance ok
ps the rubber seal isnt to expensive to buy but even a new rubber may still have the same problem as its more to do with the way the door is fitted and it seems it dont push the seal hard enough to prevent water getting in so i have found packing it out with some thick string or twine will push the seal out more and will seal it properly when you shut the door to
plz rate this solution as i have a whole page of unrated posts, thanks
The valve is leaking at the filter position. \r\nThe rubber seal inside the valve is damaged. Where can I buy that rubber seal?
You can buy online at many pool supplies. Most local swimming pool suppliers will stock popular models. There is also an o ring in the stem where it comes through the top. Don't move handle when pump is running. Turn off pump when switching positions.
1helpful
I need to buy a vev replacement rubber seal for my stainless steel stovetop espresso machine
go to http://vev-vigano.com/
then click on the small envelope on the upper right hand corner and email them with your question
Hi my Asko fridge has a freezer compartment - I
not sure why the seal is faulty but yes you can buy a rubber seal for the door go to your local hardware store you might have to look in the section that stops drafts from entering a room or rubber flex material with a adhesive tape that can be formed into any shape eg around a outlet pipe or to seal a window etc and you can always trim some rubber sealer to fit if its a little large . I used a foam roll with adhesive tape to seal my freezer door on a mini bar fridge and its still in use today
Missing a part to charge camara
please take a look at this Dock Compatibility Chart.
Here you found the name of the adapter if you need one.
The adapter can you buy as a sparepart at kodak.
Call the 1-800-235-6325 to order the sparepart.
Top Yonanas Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Yonanas Dishwasher Expert? Answer questions, earn points and help others
