Question about Yakima Fat Cat 4 Ski and Snowboard Rack
Cracked cargo box (yakima)
Didn't see the pipe in the parking gararge and now have cracks on the corners of the rack. Duct tape or is there someting special to use. would like to maitain weatherproofing
    Brigadier General:
  • 5,158 Answers
Good old duct tape... i would get some silicone caulking and run beads along the cracks in the box to seal the water out. not sure what colour that is but the caulking comes in many colours as well as clear.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 05, 2009
SOURCE:
What does 26V means in a Yakima Vertical Mighty Mounts?
It is the size of mount to fit your crossbars. Go to Yakima website for particulars:
http://www.yakima.com/shop/rack-systems/factory-crossbars
Mar 05, 2015 | Yakima Winter Sports
How do you lubricate the Thule roof box hinge?
Racks and Cracks posted a good article on cargo box maintenance which included part lubrication with silicon spray. Attached here for your convenience.
Good luck.
thule racks
Jan 01, 2014 | Computers & Internet
How do I open Yakima Skybox Pro Cargo Box without the key
How can I open a Yakima without keys. I lost my keys..
Mar 12, 2012 | Yakima Skybox Pro Cargo Box
The top won't open. First one side began to stick on the left front ball latch and now the right side won't open at all. Is there a simple solution? Should I sand down the ball on the left side? Can i buy...
When mine did the same thing, I just sprayed each mechanism with some spray lubricant to free it up, worked great. Same in the latches. WD-40 to the rescue.
Dec 30, 2010 | Yakima Skybox Pro Cargo Box
1996 ford contour, started it this morning, turned it around to back into my parking spot, let the car warm up for about 15 minutes, got in, couldn't get it out of park, turn the car off, and now it wont...
One thing to look at is the large black plastic "bellows" that comes from the intake plemun towards the air filter. It is common for these to get brittle and crack over time, especially in cold weather. The crack may be closed when the car is in neutral, but when you put it in gear, the engine moves a little and the crack opens up and creates a vacuum leak. Look it over real good and if you find a crack, some duct tape will provide a temporary solution. I hope this helps.
Feb 20, 2010 | Ford Contour Cars & Trucks
My controller do not work with my x box 360
it might be the battery on the controller or the bottom corners of your battery holder on your controller, if there cracked or broker then youll need some duct tape or electrical tape id reccoment a new controller if thats the problem, also replace the batteries. there is a slight chance there bad, if all else fails and you still ahve the receipt then you can send it in and get it replaced/fixed. hope this helped
Jul 12, 2009 | Microsoft Xbox 360 Wireless Controller
My windshield washer reservoir leaks on my '98 Honda Civic.
Ok... put the duct tape down. And back away from the truck... just kidding.. I wouldn't recommend duct tape. or hot glue...
If you have a visible crack or hole, drain the tank to below the crack, clean with a little vinegar and water, and lightly sand the plastic housing.
Place a small patch of plastic sheetrock mesh tape over the crack and then...
Use a bit of epoxy that is recommended for use on plastics. Mix up a small batch, spread over the crack and over the mesh.. Let dry and refill.
Don't worry about pressure, because the tank isn't under pressure on most cars...
Jun 08, 2009 | 2001 Chevrolet Malibu
Cracked thule box
www.recrepair.com is what Thule recommends you use to seal your crack :) -- it is an ABS patch kit and is waterproof as it is used for permanent canoe and kayak repairs. it is NASA designed.
I am using it on my Atlantis 1800.
Mar 30, 2009 | Thule Winter Sports
BLOWN SPEAKER, BOSTON
If you can get to the back of the speaker cone you could try a little touch of duct tape over the back of the crack. Pretty strong stuff and if your lucky no one will ever know!
Mar 19, 2007 | Boston Acoustics 635 System
Yakima Fat Cat 4 Ski and Snowboard Rack Logo
636 people viewed this question
Top Yakima Winter Sports Experts
Arnie Burke
Arnie Burke
Marvin
Marvin
Joseph Hoffmann
Are you a Yakima Winter Sport Expert? Answer questions, earn points and help others
