I don't get why the x box 360 controller isn't sponding in with my x box. like I move the joystick 1 second later it. moves not instantly
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
Xbox 360 E console
Xbox 360 S console
Original Xbox 360 console
ho w to fix x box from controller to x box is real - 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.pngg?v=1#xbox360s-connect-m-m.png" alt="342c6e70-9e56-43d8-bb3a-05f5411040bho w to fix x box from controller to x box is real - 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png/uploads/images/170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png" alt="170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png" class="h_mi" />
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connecteho w to fix x box from controller to x box is real - c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.pngthe ring of light that surrounds the Guide button on the controller.
If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
Connect a wired Xbox controller
Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
SOURCE: Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
SOURCE: How can i center my left joystick for my xbox 360
if the joystick is up take it apart and clean it. If its in the center and on the game the person is moVing forward then turn off your console and leaVe the joystick and don't touch it leaVe it on the floor and turn the console on
SOURCE: My right joystick on my xbox 360 is very slow and
Sad to say but you have to replace the joystick. If the joystick board is damaged, there's no way to repair it.
Hope this helps. :D
