Question about HP Compaq Motherboard
What is the 4 wire square chuck on the motherboard ?
What does the wiring diagram for the motherboard
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 2,226 Answers
It is a power plug that goes hear the cpu socket area
Posted on May 25, 2014
2 Suggested Answers
SOURCE:
  • 2715 Answers
SOURCE: wireing diagram
Download manual . ,Users guide. Data sheet. for the HP website. Your model Link below.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=62764〈=en&
Posted on Feb 22, 2009
I need a wiring diagram for connection of a 3-wire plug to my home panel - Square D, 240V, 200amp service panel.
We need to know what you are connecting. IF you are putting in a 220 outlet for stove, dryer etc. Are you in a mobile home?
Feb 20, 2016 | Square Electrical Supplies
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
If you are referring to what I think you are referring to, it's called a P4 connector, and is from the Molex family. I have attached a picture of the connector. The black wires are ground (0V) and the yellow wires are +12V.
There's often one from the PSU which you plug into the socket on your m/b. It's for (mostly) supplying power to the CPU. fc47f9e7-c9b2-4a76-b78b-78023abe79ff.jpg
I also attach a couple of pictures of the corresponding socket on the m/b. On one the socket is at the edge of the m/b; on my m/b this socket is near the middle. If you had given details of the model of your computer there is a chance that pictures of its m/b showing this socket would be on the HP website.
eddec5bf-2c7a-4d22-9335-3f0a5944d9f8.jpg 01558830-2498-4200-b062-762673d7c95d.jpg
13.April.2014
Feb 08, 2013 | HP Computers & Internet
Hello my name is Chuck and I have a craftsman 2 riding mower. The problem is I need to find out where a wire goes. the wire runs from under the fly wheel cover to just past the selinoid switch. The single...
If the wire comes from under the flywheel it is most likely the stator lead that goes to the rectifier/regulator for charging the battery...if the cust. said this was getting hot then there may be a short circuit in the charging system or the rectifier/regulator may be defective...if this model does not have a rectifier/regulator on it , then the lead most likely goes to the headlamps to power them up(only while running)
Apr 24, 2011 | Garden
My drill wont reverse
If it will not do reverse then it is in the switch not the wiring if you call the factory they can send you a wiring diagram by mail are they can e-mail it to you
Mar 05, 2010 | Bosch 1005VSRK 3/8" 0 - 2500 RPM Drill...
I DISCONECTED ALL MY CABLE SO NOW I CAN'T ABLE TO CONNECT THE WIRE BECAUSE I LOT MY BOARD CHART
it is easy...
remember this your motherboard is like a children play house red for red, square for square.. if it is not compatible for the socket it will never be placed well..
you need to connect the following..
first your main power supply to your motherboard
it is very easy to see.. it is a group of maybe 16 wires in a plastic connector..you will connect it to your motherboard..
your processor power is a four wired in plastic connector but it is square in shape..
note: take a good look in each connector they have squares cirlce, etc shapes in each wires so don't force it to connect if it is hard to it means it is not for that socket..
this is the turning point..
your power button, reset button, pw LED, HDD LED,
maybe you know where it is placed,
but note the sequence.. pw button, reset, pw led,hdd led,
if not you can try to short the pins of *********** board so that you will know where the power button will be placed...
your usb and internal speaker has their own pins....
note: take a good look to your motherboard before you connect it, it may cause you some trouble..
take a look at the + ,- signs that is encrypted in the motherboard...
you have to the red wire is fore the posite and the black is negative..
i know it is compose of four wires but they are in one socket right...
your hdd connect it i know you know that how..
that's all..
Feb 07, 2010 | ASUS P5PE-VM Motherboard
Reconnnecting wires from on my Gigabyte GA-7ZX motherboard
you can check the MB pinout diagram from their website. The powersupply connector generally of a unique size and you can easily identity by the pin numbers and safely connect it, as you cannot insert it in a wrong direction.
Nov 17, 2017 | Gigabyte GA-7ZX Motherboard
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
Apr 12, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
Jan 02, 2009 | Sony CDX-S2210 CD Player
HP Compaq Motherboard Logo
37 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
