Question about LeapFrog My Pal Violet
Information won't save to Violet
I downloaded Leapfrog Connect, so I am able to select my child's name, songs, etc that I want Violet to play. When I plug Violet in via the USB, the computer recognizes that I have plugged her in. However, once I try to save the things that I have selected for Violet to say/play, it says that the information will be saved to her the next time I plug it in. But she is already plugged in! Help please - this is so annoying!
    New Friend:
My experience is that after charging for some tens of minutes it will start. But I seem to be unable to charge the battery enough to have it work for long.
Posted on May 21, 2014
5 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: Brand new leapfrog pal violet... installed
This might be a dumb question, but does it need new batteries?
Posted on Mar 30, 2011
  • 8 Answers
SOURCE: my dauhter got the leapfrog
You have to download the software for your computer that allows you to connect Violet in order to change the name, etc. Once you do that, connect Violet with the cable included and follow the steps. If you need more help let me know. It's a little tricky sometimes if you don't do things in the precise order.
damneddle
  • 1607 Answers
SOURCE: I am trying to connect
The Eject button appears when a Leapster2 handheld is connected and turned on. When you have finished configuring the Leapster2 handheld and your child wants to play with it, you can click the Eject button to disconnect the device. Once ejected, a message will appear letting you know that it is safe to disconnect the Leapster2 handheld from the computer. It is not really a "button" but a picture of a green button which says "EJECT". It should be located on the upper right corner of your screen.
Posted on Oct 12, 2011
SOURCE: Tag will not update
I have had the same problem!! Running windows 7 64 bit. I am stuck in the same do-loop. I tried different usb port (as advised), downloaded 2 different installers from their web site, and verified the tag reader is "seen" under the USB controllers on my PC.
You also should check the following:
With TAG reader off, plug into USB port - if it does not automatically turn on device is defective.
IF it turns on do the following:
Click on the Windows start button (the small icon lower left of your computer). in the search box that comes up type devmgmt.msc and the device manager will open. Scrool down till you see Universal Serial Bus controllers and verify you see the TAG reader listed and verify there is no ! (exclamation point) next to it. If you see the exclamation point it may mean the driver is missing. If this is so right click and select properties, on the driver tab click update driver, on the next screen select browse my computer for the driver software. If you need to specify where to look try c:\Program Files\LeapFrog\LeapFrog Connect\TagUSBDrivers.
This was not my problem so I am still stuck - hope you solution was this easy. Anyone with any ideas I would appreciate help also. Customer service was unable to resolve.
Posted on Jan 04, 2013
My pal scout won't download from leapfrog connect it says error 400
I put in a new set of batteries and the data synced/downloaded to scout.
Mar 04, 2014 | LeapFrog My Pal Violet
Factory reset of leappad ultra
Download and install Leapfrog connect. If it doesn't download, there's an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Sep 12, 2013 | Toys
Leapster explorer says memory full but it's not
1) Please run the LeapFrog Utility http://lfccontent.leapfrog.com/cs/utilities/LeapFrog_Connect_Utility.exe
2) Select "Clear LeapFrog Connect User Data"
3) Start the LeapFrog Connect application and wait until the message center indicates that all Leapster Explorer Updates have been downloaded.
4) Power on and plug in your Leapster Explorer.
Jul 01, 2012 | LeapFrog Leapster 2 Learning System
My tag reader won't say my child's name
The two responses to this question have nothing to do with the question! I have a similar problem. I have a brand new Tag, connected and uploaded books just fine, but in my case it doesn't say any name when turned on/off.
Apr 03, 2012 | LeapFrog Tag Reading System
I have a LeapFrog My Pal Violet (and Scout). The have been personalized with my child's name and favorite "things". My question is: How do I reset or clear this personalized information...
Here you are. It took a while to find the instructions!
In addition, if you would like to delete the data on your device prior to recycling, open the LeapFrog Connect program, sync your device via USB to your computer, click on the product you would like to reset from the "My Products" screen, then under "Settings," select "Reset". If you have not downloaded LeapFrog Connect, please follow these instructions to do so.
eWaste
Aug 26, 2011 | LeapFrog My Pal Violet
My granddog grabbed Scout and now Scout only plays one song. The toy wasn't ripped or even a hole. Can Scout be reprogrammed? When you push the pads it trys to play something else then goes back to the...
There is a possiblity that the ciructs inside could ahve been damaged but you could try reprogramming.
To reprogramme violet you will need to install the leapfrog connect software which you can download here (Windows) or here (Mac). Then follow the instructions in this PDF
Hope this helps
Mar 06, 2011 | LeapFrog My Puppy Pal Violet
My dauhter got the leapfrog my pal violet dog for christmas before receiving this my brother programmed in my daughters name and colour ect i want to change and add info myself but when connect the toy...
Dec 29, 2010 | LeapFrog My Pal Violet
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
(Make sure your toy is powered on.)
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
Jul 02, 2010 | LeapFrog Tag Reading System
LeapFrog My Pal Violet Logo
528 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
