Dishwasher aborts wash +/-11 minutes into NORMAL WASH and LIGHT CHINA WASH cycles. Service Diagnostics indicated Function codes 6-1, 6-2, and and 6-4. Tested resistance on Fill Valve test pads P6-6 to P6-9 is 1390ohms, outside acceptable 890-1090ohms. i have no manual. Would someone instuct me how to remove, then install, a replacement please? And can i do so without removing dishwasher (again!)?
SOURCE: Child Lock light flashes continuously
allaroni No doubt the problem with your dish washer is bad key pad due to stuck button(s). The user interface you found in the technical data does not exist and what Whirlpool meant under this name only Whirlpool knows. They do not sell the key pad separate and that?s why you have to buy the complete console. Wherever you found the new part if it cost more then $150, let me know and I can get a better deal for you. Gendos post back....
SOURCE: stuck in two minute drain cycle
It is possible that the unit has leaked.
I want you to please check THIS link it will solve your problem.
Don't forget to do the banging test mentioned there.
Goodluck..
SOURCE: RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
The keypad interface is bad, you would need to replace that and then it should work great. Let me know if you run into any trouble or have further questions and I would be glad to help.
good luck
SOURCE: My KA Dishwasher model KUDSO2FR has the Normal and
sounds like a bad prosser . but ck the ribbon from the touch panel /remove ribbin and clean end retry / if this does not work / replace prosser . **** hope this helper . feed back pls .
SOURCE: Kitchen Aid Dishwasher Model # KUDS01FLSS2. No NORMAL Light?
good day,
hope this link below will solve your problem.
kitchen appliances
