Cars & Trucks Logo
Posted on Jan 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't find a bench seat for 88 bronco
I cant find a bench seat for the front of my 88 bronco. i need three seats in front. is there a bolt-and-go solution? i've gotten mixed reviews on what can easily replace the bucket seats. some have said 80-97 f-series, but others say some of those years have different bolt patterns?????
jack layton
Level 3:
  • Ford Master 5,569 Answers
  • Posted on Jan 22, 2018
jack layton
Ford Master
Level 3:
Answers
5569
Questions
0
Helped
2397362
Points
20059
I saw some bronco bench seats on ebay, they are expensive. I just did a web search. Other than that, I don't know? Call around to some salvage yards?
4 Related Answers
Anonymous
  • 109 Answers
  • Posted on Dec 02, 2008
SOURCE: Replace Front seats in 1994 Bronco
F150 seat should work in the 94 bronco if not you could remove thebraces and sliders of the bronco and put them on the other seats..
Anonymous
  • 474 Answers
  • Posted on Nov 01, 2009
SOURCE: i am trying to install bucket seats from my bench
the mount holes should be there but have body plugs covering them
Keith Love
  • 47 Answers
  • Posted on Dec 29, 2010
SOURCE: Need new front bucket seats for 1994 Bronco
typically most car manufactures have in stock, all lines of seat covers. LOL
Kdog
A
Anonymous
  • Posted on Dec 02, 2012
SOURCE: can u replace middle bucket seats with a bench seat to gain a extra seat??
We can't help you
Did they come with that option when new?
You want to convert it
Look at some other Freestars to see if they did
Maybe you can change it but it will cost too much
I would think
1990 Mitsubishi Montero. How do I remove the rear bench seat in a 1990 Montero 4 door?
Question edited for FULL 'year MAKER model'.
Question moved from Spanish car maker 'Seat' pronounced 'see-at' to correct category.
See videos and articles
https://www.google.com/search?q=1990+Mitsubishi+Montero.+remove+the+rear+bench+seat
How do I remove - pop up - the back seat bottom part of a Toyota Matrix?
2 possible places L and R bottom of seat bolts or inbetween bottom and back bolts or straps inbetween seat and back simply pull up or push seat in LS and RS pull up and out
1helpful
Do you have to remove the seat to replace the female end of the seat belt on a 99 park avenue?
thay r bolted with a sigle bolt often star head if you can fit a tool in to get at it than no you may be able to push the seat forward to get more room
1helpful
Can I replace my 98 grand prix driver's seat with
You can replace it as long as the one you are replacing is the same set-up. If you have a manual adjusting seat and replace it with a power seat it will fit but you wont have the hook ups for it. Also make sure if it is a bucket seat (single person) you dont replace it with a bench (3 persons fit in front) seat or you will run into problems with the center console and shifter. vice versa may bolt up but there will be a gap between the 2 front seats
2answers
How do you change the oil in the rear axile of a 4wheel drive 2007 tahoe
Hi, the axle has a drain plug at the bottom, removing this plug allows all old fluid to empty, put the plug back in, and tighten. fill back up with 2-3 qts of 75 synthetic weigt oil. Good luck...Coop
Does an 86 ford bronco ii have more than 4 seats
all bronco II's that i have seen have 2 bucket seats up front and 1 bench in the back that usually had 3 sets of seatbelts.
Remove the back seat from chevy celebrty 1987
Push lower end of rear seat back to unlock clips (takes a bit of effort)
Lift bench out
Should be clips or bolts holding the top of the rear seat - release these
Push up on the upper section of seat to release top clips.
in some car models
Remove the 10mm bolt behind the bench near the seat belt fastening sight and then lift the seat up from the back to the front..towards the front seats. The clips are angled down and in so that the back has to lift up first.
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
10helpful
How to remove the back seat from my 1998 Mercury Villager
it is not designed to be removed. It is designed to slide back and forth as needed.
Section 01-10: Seats and Tracks 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Seat, Rear Bench
Removal
  1. Remove the center seat(s) if equipped. Refer to the procedure in this section.
  1. Slide the bench seat forward to the center row seating position.
  1. Use a flat-blade screwdriver to remove the cover caps from the front of the rear seat cushion latch cover.
  1. Remove the two rear seat bolts from the front of the rear seat cushion latch cover.
  1. Lift the rear seat cushion floor cover on the back of the rear bench seat and remove the two inboard rear seat bolts and the two outboard rear seat bolts.
  1. Remove the bench seat from the vehicle through the body side door opening.
9helpful
2answers
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
2answers
How do i remove rear bench seat from 08 lancer es
Not 100% sure on that particular model but usually you either have a couple of bolts at front of seat down close to floor to remove, one on each side, and if no bolts, you grab front of rear seat, push back on it hard & lift, usually a catch on each side.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
