Eric The mouse moves fine around the screen. Its only when I have to click to open anything up. I have to click three or four or more times for anything to open. It didn't start till I got the new monitor. PhilEric The mouse moves fine around the screen. Its only when I have to click to open anything up. I have to click three or four or more times for anything to open. It didn't start till I got the new monitor. Phil
You can't post conmments that contain an email address.
We had a similar problem with ours when connected via a KVM, response was very slow or laggy, resolved it our side by adding a USB extension cable and putting the USBport antenna off to one side away from the switch and screen, works fine now so could be interference.
I am using my tv as a second monitor as well, and i believe the lag problems with the monitor are due to the video/graphics card. I am not expert, but my pc is an alienware aurora with quad processors and 6gigs of ram. The only thing not top of the line is my video card, plus it gets slightly pixelated due to resolution not being sufficient from my video card. Otherwise flight sim X runs smoothly, except for the mouse lag issue. Best of luck, if your program is lagging also though, might be your driver
Looks like you have a memory leak of some sort. Press Ctrl+Alt+Delete on your keyboard, and task manager should come up. If your computer is set up differently, then a dialog box will come up with a six buttons on it, you should click on task manager. Go to the preformance tab, and you should see your memory usage. If you go to the Processes tab, you should be able to see which process is using the most memory. From then on (depending on whether you have more or less computer experience) you should be able to solve the problem yourself. If you don't have much experience, just report back with as much detail as you can manage.
Hi my new hp bluetooth laser mouse does not work. It will work, then when you switch users, or turn off the computer and then turn it back on, it stops working and will not work after that.
