SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
SOURCE: pride mobility scooter wont move
hi, that noise could be a relay clicking off inside the motor controller because the brake on the motor has failed to release,
It quite a common problem and the only way to be 100% sure is try a replacement brake unit.
Regards
GeWiz.
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
