WHEN WATHING DVD ONLY PLAYS IN BLACK AND WHITE , TRIED DIFFERENT PLAYER AND DISCS NO CHANGE TV WORKS FINE NORMALLY AND WITH VIDEO AND FREE VIEW JUST NOT WITH DVD PLAYERS.
SOURCE: Panasonic TH-42PD25
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for $60. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthrea... if you want, contact me by replying and I can mail you the jig temporarily for $10 plus S&H. You'll save money and it worked for me, i just need it back.
SOURCE: PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus. If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
SOURCE: no video
try checking what your dvd is set on ie rgb pal or nstc, then check in your tv manual what inputs it accepts
SOURCE: Sharp DV-NC 200 (DVD) Panasonic TX-32LXD700A (TV)
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Unfortunately, if the Sharp DV-NC 20 was bought in Australia, it would not allow any mods/hacks to make it region free. Sorry. Additionally, even if the Sharp could be made to change regions, the Panasonic TX-32LXD700A uses a Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G. it is (again) hardware limited to the PAL Colour System (Region 2).
Good luck and Thank you for using FixYa. Happy Holidays.
Pls be informed that due to my current rank and rating, even a
Helpful would be detrimental to my status. Should this solution not address
your concern, it would be appreciated if you could just not rate it at
all. Cheers.
SOURCE: Sharp dvd and Panasonic tv not compatible?
thats got to do with the dvd aswell as the player, most dvds are locked to specific regions, the only suggestion i have is to get DVD X Player Pro for the pc since that will let you play and region dvd on your pc no matter what the drive is locked to.
