SOURCE: Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
SOURCE: GVX2 krups coffee grinder; how to open it?
I have the same issue. You need to take both dials off, then on the bottom, there are 4 tabs on the inside. Seperate the halves and you will see them. Towards the front and halfway back. Pry the halves apart enough to push the top towards the bottom and it slides apart pretty easy. The tricky part now is finding the replacement part. I have super glued my switch and I want to do something to try and repair it further. Maybe epoxy. I called Krups and they can't sell the part to me. I called one of their service centers and they can't sell the part to me. So, if someone knows where to get the part, I am all ears :)
SOURCE: Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
SOURCE: I have no maual for my KRUPS type GVX2 coffee
Hi There, you can get your manual here just download it and save it to your pc and you can print off a copy
http://www.krupsonlinestore.com/manual/55351.pdf
SOURCE: Missing user manual
Hello you can download your user manual directly from here
