Panasonic TH-42XVS30U 42 in. Plasma HDTV Logo
A
Anonymous Posted on Feb 08, 2013
Hp tv cptoh-0602 keeps shutting off and half of a picture
Tv keeps shutting off cable connections are fine tried different outlets and when it does come on I only have half a picture the right side is colored stripes
3 Related Answers
Anonymous
  • 217 Answers
  • Posted on Feb 17, 2007
SOURCE: half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Anonymous
  • 4889 Answers
  • Posted on Dec 07, 2010
SOURCE: I have a Panasonic TH-50PX60U plasma TV. The
Can you get me a good shot of the screen, so that I can see for myself what it looks like? I do not want to suggest anything without seeing the image first.
Anonymous
  • 14553 Answers
  • Posted on Apr 02, 2012
SOURCE: panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
1helpful
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Hi! I have a 2006 HP High Def Plasma TV model CPTOH-0602, serial CNH6131576. It lost picture, I can hear sound. Wonder what couls be the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
I have a panasonic 50" model TC-50S1 i turned it on and the picture was messed up it then shut off and the red light keeps blinking one time
Try unplugging any HDMI cables from the TV and plugging the TVs power cord into a different wall outlet.
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
2answers
My picture is flickering but there the sound is
Did you try buying a new HDMI cable? You can also try some of the solutions in the post called "Hp 42 plasma tv cptoh 0602 I get sound but no picture."
Hp 42 plasma tv cptoh 0602 specs all the time and wavy sd video
Mine has done this from day one, appears to be a resolution problem. All I do is go to a HD channel let it tune in and then go back the the SD channel and don't have to worry about it until next time the power has cycled.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
