I have Foxpro 2.6 Dos application . I try to print the report in laser printer HP LASER JET 1020 and no print comeout. It is printing in lpt1 printer dot matrix,. What is the solution? Please help
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Dos based applications like fpd26 doesnt detect an usb printer one way of directing output to USB is by using NET USE at command line
share your USB printer and give its name at printer share name
Ex. NET USE LPT1 \\<computer name>\<printer share name> /persistent:Yes
Open the printer properties, select ADVANCE tab select PRINT PROCESSOR select TEXT, apply the changes
at the command prompt type DIR >PRN this must give you print from USB printer, then try printing from your application
Dos2usb and dosprn are the softwares to solve our problem
1020 in no print
Win print software download in the laser print in out put dos promot
I have foxpro 2.6 dos application. i try to print the report in laser printer Hp laser jet 1020 and no print comeout
* For text ads, append each ad to the string.
for(i = 0; i ' +
'Ads by Google' +
google_ads[i].line1 + '';
url = '' +
google_ads[i].visible_url + '';
info = makeBoldAdWords(google_ads[i].line2) + ' ' +
makeBoldAdWords(google_ads[i].line3) + '
s += url + info;
s += '';
s += '';
document.write(s);
G_GGL_SKIP += google_ads.length;
return;
var G_MAX_ADS_WL = 1;
google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#)
google_ad_channel = "2849999023+2438490332+4447185069+2073327721";
google_ad_output = 'js';
google_max_num_ads = '1';
google_ad_type = 'text';
google_feedback = 'on';
if(typeof G_GGL_SKIP == 'undefined')
G_GGL_SKIP = 0;
google_skip = G_GGL_SKIP;
Hp laser jet p4014 printer is printing black
