Lands Phones Logo
Posted on Feb 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove DND in Nortel N441
Nortel N441 is in DND model, because of which I cannot get calls to the extension. How do I disable the DND.
  • Anonymous Mar 19, 2014
    someone had the phone before me and set up their voicemail. That person has since moved on and I need to reset the voicemail but no one knows his password. How do I fix this problem
Anonymous
Level 2:
  • Expert 192 Answers
  • Posted on Mar 24, 2009
Anonymous
Expert
Level 2:
Answers
192
Questions
Helped
239366
Points
557
To disable DND on a Norstar system,
dial FEATURE # 8 5
from the set.
2answers
What headsets are suitable to use with the Nortel N441 PHONES ?
The Nortel N441 appears to be little known and there is no one saying you can get a headphone for it.
https://www.google.com/search?q=Nortel+N441+headset
No manuals for it.
https://www.google.com/search?q=Nortel+n441+Phone+User+Guide
1helpful
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
My nortel n441 says locked mailbox this happened after trying to change password can you help me
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the phone you are using.
2answers
1helpful
Calls don't go to voice mail if on another call
You need to go into programming and set the FWD NO ANSWER, to go to the voicemail extension.
Also check FWD ON BUSY, that should go there as well.
1helpful
Cannot make outgoing calls
One doesn't necessarily equal the other, but start with the DND first :-)
Press FEATURE #85. DND off. (FEATURE *85 puts it back on).
Now, if everything works, skip the rest. If not, press FEAT *0 and press all the buttons on the strip below and above and note what it says. It should match what other phones have programmed. If it doesn't, post back as a comment and we can start working on that.
Carl
1helpful
Unable to see if an internal extension is engaged
It doesn't exactly work that way, but you can program the extensions back under the buttons. Pick a button that you want to save an extension under and press FEAT *2 the button and dial the 2 or 3 digit extension number. Now the button monitors the status of the extension. It will light whether it's in DND, or busy on an outside or internal call.
Carl
1helpful
No message light
Have you tried a FEATURE #806
Feature 806 means Static time and date, but sometimes it shuts off the message waiting indicator lamp???
Not too sure why, but give it a try.
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
