SOURCE: Once trigger is depressed, air leaks and no nail is fired....
Sounds like the trigger o-ring is damaged, either because of not being oiled frequently, or the pneumatic tool has not been used for a while. O-rings will harden up if not used. Look for a place that sells fasteners, or nails and see if they can put a new o-ring in the trigger asm. for you. If you take the gun to a place where you purchase your nails, they should repair for little or no cost. it is an easy repair if you have the tools, parts, etc.
SOURCE: Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
SOURCE: DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
SOURCE: Dewalt 51488. Air leaks around trigger and won't fire nail.
Go to Dewaltservicenet.com and download a breakdown of the tool before starting. I would recoment changing all the O rings and make sure that you get a good grease to lube them first. Its not that hard.
SOURCE: My dewalt cordless finish nail
there is a lock in rear right side (small black rubber thing) us push it back!
