RTO THERMAL DYNAMICS CUTMASTER 102 PLASMA CUTTER 1-1330-1 Logo
A
Anonymous Posted on Feb 07, 2013
Flashing red light on cutmaster 102 - RTO THERMAL DYNAMICS CUTMASTER 102 PLASMA CUTTER 1-1330-1
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
2helpful
I need codes for tv for philips universal remote
Here are codes for Universal Philips Remotes for Televisions. Directions at the bottom to enter codes.. Good Luck!
ABEX ................................. 120
ADMIRAL ................. 701 918
ADVENTURA .................. 019
AIKO ................................. 407
ALLERON ........................ 206
AMARK............................. 603
AMTRON.......................... 906
AKAI ................................. 801
AMSTRAD ........................ 520
ANAM NATIONAL .104 805 901 906 920
AOC ............ 002 003 102 119 217 302 502 814
ARCHER ........................... 603
AUDIOVOX ...................... 906
BANG & OLUFSEN ......... 620
BELCOR ............................ 002
BELL & HOWELL .......... 506 601 701
BRADFORD ...................... 906
BROKSONIC .............. 215 316
BROKWOOD.................... 002
CANDLE .... 002 019 402 502
CAPEHART ...................... 119
CELEBRITY ..................... 801
CENTURION.................... 502
CETRONIC ....................... 805
CITIZEN .... 002 112 402 407 502 512 701 805 906 319
CLAIRTONE .................... 003
CLASSIC ............................ 805
CLP .................................... 016
CLP CLASSIC .... 013 012 001
COLORTYME ... 002 502 602
CONCERTO ............... 002 502
CONCIERGE ..................... 713
CONTEC/CONY .......003 802 805 902 906
CRAIG.........................805 906
CROWN......................805 906
CURTIS MATHES ............ 002 103 112 502 506 512 601 701 704
CXC ............................. 805 906
DAEWOO .. 002 102 110 214 303 311 314 403 407 502 503 611 805 809 909
DAYTRON................. 002 502
DIMENSIA ................. 601 704
DUMONT .................. 002 713
DYNASTY ........................ 805
ELEKTRA ........................ 701
ELECTROBAND ...... 003 801
ELECTROHOME ..... 002 502 803 901 914
EMERSON . 002 003 004 005 104 105 106 115 204 205 206 213 304 305 316 319 405 502 505 506 519 604 605 705 804 805 903 904 905 906
ENVISION ..................002 502
FISHER ....... 506 606 619 902
FUJITSU ............................ 206
FUNAI ................ 206 805 906
FUTURETEC ............805 906
GE ........ 002 006 007 018 107 114 310 312 502 601 704 719 803 806 810 901 911
GIBRALTER .............. 002 713
GOLDSTAR 002 102 117 207 217 307 502 818 914
GRUNDY ....................206 906
HALLMARK .............002 502
HARVARD ......................... 906
HITACHI .... 002 016 116 216 315 502 507 515 519 607 615 701 707 715 815 902 915
IMA .................................... 906
INFINITY ......................... 807
INTEQ ............................... 713
JANEIL .............................. 019
JBL ..................................... 807
JCB ..................................... 801
JC PENNY ......... 002 007 102 107 112 310 312 402 502 512 601 704 719 803 806 818 907
JENSEN ......................002 502
JVC ...................... 007 107 108 308 510 607 902
KAWASHO ......... 002 502 801
KAYPANI .......................... 119
KEC .................................... 805
KENWOOD ....... 002 502 914
KLOSS NOVABEAM ....... 019 408 508
KONKA .............. 203 208 219 306 317 417
KTV .................... 003 213 319 608 703 805 906
LODGENET .............. 601 701
LOEWE ............................. 807
LOGIK ........................601 701
LUXMAN...................002 502
LXI .............. 002 312 502 506 512 601 704 719 807
MAGNAVOX ..... 002 009 109 118 209 309 402 408
502 508 510 807 914 917
MAJESTIC ................. 601 701
MARANTZ ........ 002 502 807
MATSUI ............................ 807
MEGATRON ...... 002 502 507
MEI .................................... 003
MEMOREX 002 115 206 502 506 601 701 706
MGA.................... 002 102 206 502 619 803 914
MIDLAND ......... 007 107 312 713 719 818
MINUTZ ........................... 806
MITSUBISHI .............002 102 206 502 510 619 709 803 814 914
MONTGOMERY WARD 601 701
MOTOROLA .............901 918
MTC.................... 002 003 102 112 502 512
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
2helpful
I dont have the manuals to my philips universal remote so i need to add componts dvd
Try this link, http://www.universal-remote.net/philipsmagnavox.html
or instructions are as follows - Direct Philips Magnavox Universal Remote Code Entry PM335
DVD, etc.).
brand.
TV
1helpful
I have a universal remote control which is philip and tv set which is also philip but I dont know the code to be used.
DVD, etc.).
brand.
TV
please do rate the solution positively.thanks
Tray won't open, no buttons work
Return it. do not open it up or you will void any warranty. There is either a disconnected cable or a logic/power problem. In any case, a new piece should work out of the box.
Dan
Machine will not come on
Hi there
Sounds like a typical Ballast ( lamp's powersupply ) problem.
Top RTO Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
