I have the same problem and left the breaker off for about 2 hours. This failed to reset the issue. The manual suggests a heater circuit issue. I haven't taken it apart yet but I suspect there is a circuit board issue. Any suggestions????I have the same problem and left the breaker off for about 2 hours. This failed to reset the issue. The manual suggests a heater circuit issue. I haven't taken it apart yet but I suspect there is a circuit board issue. Any suggestions????
You can't post conmments that contain an email address.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
On our Kenmore Quietguard the lock light is at the Air Dry button. Holding the Air Dry button for about 8 seconds turns the lock light off if it is on and on if it is off.
press heated dry
press normal wash press heated dry again press normal wash again.......... .....wait a few seconds all the lights should come on press cancel (should hear pump) hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Just for the degergent item.....The Sears repairman told me to not use the gel type detergent but only use cascade complete and to use very little of it..
