Question about Nor-Lake Freezers
Wiring diagram zf122sas
Need to use wiring diagram for Nor-Lake freezer mo# zf122sas
2 Suggested Answers
SOURCE:
  • 1282 Answers
SOURCE: having wiring problem freezer works
I have a generic wiring diagram that I use on all my installs that works very well. It is basically the same for most all commercial walk in freezers. Send me a email address and I'll scan and forward what I have.
Posted on Oct 16, 2010
I need a wiring diagram for a Nor Lake walk in freezer
Contact the Manufacturer stated on the box itself or the data plate. Customer Service can send one right out for you. Roger
Apr 22, 2014 | Freezers
My defrost timer was replaced by a brand new one, two days ago -- the defrost light turns on for 1 minute, another few moments after, the green light turns back on again.. my temp wont go down and I am not...
sounds like a bad defrost terminator or timer wired wrong. won't make temp as the evap is not clear of ice/frost build up. check your wiring diagram for location and operation of terminator.
Nov 15, 2013 | Nor-Lake KLF7766C Commercial Freezer
I changed the defrost timer on a cpf50c and lost my position tags on two wires. I need to find a technical manual with a wiring diagram.
L1 goes to 1-2 on Clock, L2 or Neutral to N on Clock, Defrost heater to 3 on Clock, Defrost Limit/Fan Delay to X on clock
Dec 09, 2010 | Nor-Lake Freezers
Having wiring problem freezer works but fans dont come on aod defrost timer dont kick in need a wiring diagram the serial number is . 88202021 and model number is . gf2ssd for a nor lake reach in...
Oct 10, 2010 | Nor-Lake Freezers
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
Temp -35 degrees,freezer runs all the time
I assume there is no manual control for setting temp. so the thermal sensor or control circuit has failed and it is just staying at its maximum.  You will probably get more help from the manufacturer but their website is somewhat disjointed; looking for contact info for your product ends at one point and then shifts to their scientific product line.
The only general contact info I found is here:
Nor-Lake
You will in any case need to have the correct model number at hand since the subject line doesn't sound like your freezer.
Apr 02, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
Top Nor-Lake Freezers Experts
Dennis Boxerman
Steve Allison
Steve Allison
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
