Old MP520 print head stopped printing black ink after I cleaned it with isopropyl alcohol. Bought a BRAND-NEW print head from Canon and installed all new ink cartridges and it STILL doesn't print balck ink. Everything else prints/works fine but it doesn't print black ink. I've cleaned and deep cleaned the head but I get nothing. WTF?!
See if this link helps you find out why.
MP520 won print black ink Google Search
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
SOURCE: canon ip5000 won't print black
try taking the cartridge out and cleaning it then replace it after that unplug it for a couple minutes and then plug it back in and let me know what happens
SOURCE: IP90 stopped printing black
I switched to composite black, then back to all black. After composite black printed out, then all black was ok. It was a software problem, not a hardware problem. Try this first! Mike from Burlingame
Use the printer's utility program to self-clean the printer.
This process may need to be repeated as many as 5 to 10 times. Often this will
resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning
utility has not worked. The ink may need to soften before the self-cleaning
utility will be successful. Turn the printer on and try the self-cleaning
utility again several times.
Determine
from the owner's manual where the print head is located. Epson printers, for
example, are usually in the printer. Many other brands place the print head in
the cartridge.
Remove
the cartridge. For models where the print head is in the printer, drop seven to
10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area.
This is the hole where the ink flows into the head from the cartridge. Run a
few self-cleaning utilities. If necessary, allow to sit a few hours or
overnight and repeat the self-cleaning utility.
Soak the
cartridge print head in hot water if the print head is in the cartridge. Allow
to soak overnight. Dry the print head area with a paper towel. Repeat the
Place the
cartridge print head in isopropyl alcohol if the hot water soak did not unclog
the print head. Leave the print head covered in alcohol overnight. Use a damp
paper towel to wipe off the print head area. Dry carefully. Try the
self-cleaning utility again.
Purchase
a new cartridge if the alcohol soak did not unclog the print head in the
cartridge. This will provide new print heads that won't be clogged. Contact a
service technician for repair of print heads in the printer if the alcohol did
not unclog the print head.
