I have a Casio G-Shock model dw-9051 (the "classic" style)-unlike everyone else, I can't get my alarm to go ON. The icon for the alarm chime is there, and I can turn it on and off with the alarm on/off button (top right). When the time comes around the watch blinks as if the alarm is going off but I have no sound. I don't have a manual so I'm confused-since this watch may have applications for the military, is there a way to deactivate the alarm chime for safety, and if so, what is this procedure? Other than the chime module being shot I can't imagine why it's not going off when it is supposed to. Thanks.
Check if the spring is in its place. Also, check if the spring is oriented in the right way.
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
The problem is the piezo alarm inside the back of the watch, once the thin coating on it is scratched off, it will no longer work. If you look, there will probably be a scratch where a spring or small piece of the watch works touch it. This happens when the back of the watch is removed and replaced sometimes. If you replace the back of the watch it will work again, but good luck getting another back.
SOURCE: casio g shock dw-9052 how to change from military
You can get instructions from the Casio web site which will tell you how to set your watch..
Go to the casio
web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read
the number of the back of your watch and enter it into the search box
SOURCE: spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
SOURCE: TGHK hourly chime, and military time
Go to alarm screen and press light and st/sp at the same time.
g-3011 i replaced the battery & now when alarm is set the light flashes but no sound.
