What is the HP range on the Haier AES44b refrigerator? It is 115v 60Hz (I am trying to buy the correct 3 in 1 starter kit)
What is the HP range on the Haier AES44b? It is 115v 60Hz (I am trying to buy the correct 3 in 1 starter kit). Starter kits are sold using both volts and HP range
Unless you are an experienced electrician this is not something you want to do. Improper wiring could result in fire or an electrocution Call for service.
just make sure the specs for the replacement plug is correct:
AC ADAPTER
input: 110-115V 60Hz
output: 12V 500mA
pin size that plugs into the unit ~ 9mm or a bit tad over 3/16"
with that adaptor, it takes up to 36 hours to charge it up to FULL
with a comparable DC adapter, it takes only 8-10 hours
HAVE YOU CHECKED THE SWITCH ON THE COMPRESSOR OR THE FUSE ? AND IF THE COMPRESSOR IS KICKING ON CAN YOU HEAR THE BLOWER FAN KICK ON ? IF ALL IS GOOD THEN YOU HAVE A BAD CONDENSOR THAT WILL BE THE NEXT THING TO CHECK
Yes, those motors shoudl be pretty standard stock items at any local appliance parts supply house found in the yellow pages.
You might also try lookinmg under "motors and controls" in the yellow pages. If you get it locally like that then you can physically compatre the old one with the new one to make sure it is indeed the same part.
Thats better than an online link with just pictures.
it replaces the factory,start relay overload and run capicitor,you can get it at any appliance part store in your area,it tells you how to do it to,very easy,let me know-mike
