Goodman CKL42AR42 Air Conditioner Logo
munivai j howard Posted on Feb 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats the normal presure for r410 units - Goodman CKL42AR42 Air Conditioner
william simpson
Level 3:
Genius:
  • Goodman Master 1,363 Answers
  • Posted on Aug 14, 2015
william simpson
Goodman Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
318109
Points
1636
118psig on low side & 350 psig on high side.
2answers
I have a trane air conditioner operating at 70psi low side pressure but with little to no temperature on liquid line by condenser but is cold to the touch entering the air handler
What type of refrigerant? R22- 70psi is good/ r410- 70 psi not good. What is the head pressure, is the filter clean, is the coil frozen, is the fan operating properly, all the supply air grills open...lots of things cause funky pressures. Need more info
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2answers
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
1helpful
2answers
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
2helpful
Can you put a 410a air handler with a r22 condensor
No. R22 and R410 are not compatible. R410 units operate at much higher pressures than a comparable R22 unit. These refrigerants also use different types of oil which are not compatible. If you need to replace half you might as well replace the whole unit because I was told that as of January 1 of this year you can no longer buy an entire R22 unit unless it is one a dealer still has in stock. They are phasing out R22.
1helpful
What's the remote code to activate with a
I have found the code for the Toshiba D-R410 DVD recorder ! The code that works with my Radio Shack family 5 in 1 remote is:
1008
I hope this helps !
How can i unlock my samsung r410? i forgot my user lock
my samsung r410 is locked and i dnt know the 4digit security code.......help me plzzzzz!
Maytag Refridgerator Commpressor kicking thermal overload
Hey, it might sound strange, but check both your high and low presure switchs, then check your charage presures, both high and low, there also may be clog in the ststem somwhere.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
