Low beam headlights not working when switched on. Pulling the lever to high beams works the high beam lights only.
If your car is running daytime running light system .. there is a DTR relay that goes defective and needs replacing ... I had the identical problem that was fixed with this replacement. The DTR relay is behind the glovebox.
There should be a fuse and/or relay that operates the low beams, or try replacing the bulbs.
Step
Action
Value(s)
Yes
No
DEFINITION: This diagnostic procedure should only be used if the high beam headlamps are operating properly and the low beams are inoperative.
Did you perform the Headlights System Check?
Go to Step 2
Go to Headlight System Check
Does the test lamp light?
Go to Step 3
Go to Step 5
Go to Step 4
Go to Step 6
Go to Step 7
Go to Step 8
5
Replace the headlamp dimmer switch.
Is the repair complete?
6
Repair the open in CKT 359 (PPL) between the headlamp dimmer switch and the daytime running lamp relay.
7
Replace the high/low beam headlamps.
8
I have the exact same problem... did u find the solution? Did rdegan's solution work?
when I push the high bean lever up it does not click on or stay, low bean clicks on
