Stops running after it watms upI can get the yard broom to run but when I squeeze the trigger it starts slowing down and cuts off.
Is the an electric blower or gas?. if gas, you can be experiencing blockage in the fuel line or water in the fuel tank. if electric, this may be a wiring problem. you could also have restricted air flow due to an dirty air filter as well.
I have not seen one that is worth taking to the shop to repair. It sounds like a fuel and or air problem if you are getting spark (assuming the coil is good).
For fuel, the filter/lines could be cracked or clogged. The carb could be gummed up.
Worse would be if you had an air leak.
Check that your air filter is not clogged.
Motor connection or faulty or weak motor problem.just check the wirings and the motor carefully.
