This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation
before sending any faxes. Select either
On Fax Send or
Send & Receive.
The default fax confirmation setting is
Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press
Setup.
2. Press
2, and then press
1.
This selects
Print Report and then selects
Fax Confirmation.
3. Press to select one of the following, and then press
OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip If you choose
On Fax Send or
Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the
Fax Sent Confirmation report. Press
Setup, press
2, and then press
2 again. Select
On from the
Image on Fax Send Report menu.
The monitor button only beeps and does not do anything. I was not sucessful in making this work. Any other help you can offer?
Thank you - the star was the missing link - it works now. Thanks!
