Frigidaire ATF6000ES Front Load Washer Logo
Posted on Feb 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer will not operate properly with full load--decrease load and will spin
When washing if full load is put in when washer goes to spin cycle with not drain all the way or spin, but when half of load is removed will run properly.
  • Official Brand Answer 4,342 Answers
  • Posted on Feb 10, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467766
Points
5907
Hello sismurphy1 - Does the washer make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Aug 04, 2007
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Anonymous
  • Posted on Aug 12, 2008
SOURCE: Washer will not Spin during SPIN CYCLES
IT IS THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE, THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. I FIXED MINE MYSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY, BUT I SAVED MYSELF $250.00. YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 04, 2008
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Anonymous
  • 750 Answers
  • Posted on Dec 05, 2008
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Anonymous
  • Posted on Aug 30, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
2answers
My roper top loading machine washes but will not advance to rinse it fills up but drains immediately after.
Please power cycle your washer (ie unplug power for 2 minutes before powering on again). Then, you can move your dial counterclockwise (or opposite the direction that you currently turn your cycle-setting dial) by 90 degrees. Then, attempt a full cycle again. This should help somewhat reset your cycle functions so that it works properly.
Thank you.
2helpful
3answers
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Doesn't spin
  • yes it does sound like the timer is bad.
  • the timer has small contacts in it (sort of like a music box) that lift and rest in certain places.
  • these contacts may not mate properly as the timer goes around slowly in the normal operation.
  •  but when you manually turn it is a faster turn and the contacts will fall faster and get a better connection.
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
