I really don`t know how to open the case of one of the speakers.The cord is broken somewhere inside the case and i can`t find screws or clips on the hard case. Thanks.
First open the net over the speaker...top bottom corner there is a hole then in this hole put a strength stick pressure heavy by side..then it will show u crack by this crack u have to open it!!remind there is no screw in s-100 logitech speaker!!Thanx!
SOURCE: Logitech Z-5500 Speaker stand problem
The stand was held on with a nut on the inside. There is not longer a nut on the inside of the hole, so there is now nothing for the stand screw to attach to. The nut is now stuck to the magnet on the speaker. You will need to disassemble the speaker housing to remove the nut from the speaker magnet and reattach then stand. peace. Paul.
SOURCE: Computer satelite speaker dead... How do you open up the satelite to get inside???
I had this problem as well, I finally figured out that the rubber plugs that allow you to remove the dust cover are able to be pulled off. Get a pair of plyers and just yank em out, which will reveal 4 discreetly placed screws :). I am having somewhat of the same problem you are however, and opening the speakers up did no good for me, the wiring seemed fine but I still get a rattling or complete silence whenever I exceed a certain volume. Let me know if you manage to find anything out and if you solve the problem, I'd like to try it so I don't have to try to find a replacement satellite. Jeremy
SOURCE: Logitech x-530 speaker problem
Try going through this troubleshooting procedure site first: http://logitech-en-amr.custhelp.com/cgi-...*uWZ8vi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz04NDQsMTcmcF9jYXRzPSZwX3B2PTIuMTcmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1 If you get no solution from this, there are other similar logitech speaker systems that have had similar problems on initial models. it appears that logitech have been very helpful with replacing speakers in the past if design or product is faulty. Give them a try. hope this helps:)
SOURCE: How do I open Logitech S100 Computer Speakers?
most of the logitech device are plug and play, all you have to do it just plug it to the computer CPU and it will turn on automatically
SOURCE: I have the Logitech Z130 speakers, and the left
could also be a damaged wire, check that first by "feeling up" the wires, does it feel cut or interrupted somewhere? if not, you can open the speakers by lifting or prying out the rubber cushions on the bottom side and removing the screws. Remember this voids your warranty, if it's still applicable.
