SOURCE: Hello my Dell Inspiron 1545 laptop has a huge
You also need to be sure you are not covering the vents when you use it. Using it on a bed or surface that smothers the vents is bad for the system.
Check to see if you hear the fan running. Do you feel air blowing out of the vents? AND how hot is that air?
It should be warm, not hot.
If you feel no air the fan is not turning on.
These are things you need to tell DELL when you contact them.
SOURCE: lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
bluescreen can be caused by a number of things
a bad driver loose or faulty lead or not having enough ram
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
if you dont want to install more ram uninstall some unnecessary programs
a bad or faulty motherboard lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
hope it helps
