Email: [email protected]
COF 32 ATDC sensor failure.Enter in the service mode select Then.rep.mode select printer mode select ATDC gain adjustment note the current value then clear the current value and change the value up or down.Ex: the current value = 150 clear and change to 154 ,make a few copy and if the error code not displayed is OK.If the error code is appaire clear the value and enter 132,make a feww copy,if OK you are resolved a problem.
Service mode entering:
press utility key-press metercount-press details(if apaire the details windows)-press Stop 0 0 Stop 0 1 (if appaure admin code press 00000000 ) select techn.rep.mode-printer etc.
SOURCE: COBAO error on NEC IT3520/KM Dialta 2010
Sir,
Was there a trash can or box of paper underneath the finisher part that moves up down. the code is failure of the up and down motor for the finisher. Normal happens when the trays that move down they hit something. or the mootr has failed. Open/close the door to the finisher, power off both power switches including the one on the rear left side and the one on the front panel. wait ten seconds then turn them on again. Also check to make sure there is not something binding the tray system
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: fixing code cof32
You must have cleaned the developer in the right side of the image unit, the reason for the code because the sensor doesn't detect toner and developer. You don't mension the make and the model, I presume is a Minolta. If you tell me ,I can tell you how to sort that out.
GOOD LUCK.
SOURCE: minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
SOURCE: Canon IR 3180C. Error code E000008-0001.Enter mode
click this link to find the service mode procedure
and here is the service manual:
http://www.4shared.com/file/P_7SU82j/ir3100c-smpart1.html
http://www.4shared.com/file/6X_eK9Cx/ir3100c-smpart2.html
SOURCE: Hello we have a canon CLC 5100 , it keep give us
This is an issue with the oil supply unit if the motor is working ok check the unit for any broken parts like gears
