SOURCE: Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
SOURCE: Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
SOURCE: STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF.
Actually, I think I found the problem. I took the light out and cleaned the filter (screen) on the light cartridge. I turned the tv back on and it still gave me the message. As the tv was still on, I tapped on the fan that sends air directly to the light cartridge and the message went away. About 2 days later, I got the message back but went I shook the tv and tapped it on the stand a few times, it worked. I think that particular fan is going out and seems to be a problem with other tv's as well. Any ideas where I can buy a fan? Hope this helps you all out.
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
