I have an MSI KM4M-V KM266-8237 motherboard with an 2Ghz AMD Sempron, 1 gig of RAM and an NVIDIA GeForce 5500 OC 256MB AGP 4X video card. Sound, LAN, etc. are onboard. I'm trying to install Windows 7 and every time the computer loads Windows off of the installation DVD, it gives me an error before ever getting to a GUI. The error says "classpnp.sys" cannot be found or loaded.
In searching, I've found that this might be due to the BIOS settings that the NVIDIA installation guide recommends, specifically a setting that recommends turning OFF a PnP aware OS and how this might conflict with IRQ setting. However, I never found that setting in the Phoenix BIOS so I never changed it. I'm running version "6.00PG" dated 7/28/2004 and haven't found any BIOS updates via the MSI Live Update utility.
Am I on the right path or way off in trying to get Windows 7 installed?
• HyperTransport 1.0 supporting speed up to 1000MT/s
Chipset
• NVIDIA® nForce 630a & GeForce 7025 chipset
Main Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
Slots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
On-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
But this computer IS an upgrade! Hah
According to reviews Windows 7 is less resource hungry than Vista, which was one of Microsoft's goals. There's even a review that runs it on a 1.8Ghz with 512Mb of RAM and 64Mb shared video. I can run Ubuntu 8.10 with full Compiz fine and I really just want to dabble with Windows 7.
If I could just find the PnP option in the BIOS to see if it's ticked or unticked. I was searching around through it again last night and didn't find jack...
