When upgraded from windows vista to windows 7 the second display stop working, it went dark. I reinstalled windows vista and the direct console 2 but no help. any help solving this problem will be greatly appreciated
SOURCE: Ram upgrade
most laptops have a compartment with a led held by a screw on the bottom of the laptop, look under there, typically 1 or 2, RAM and/or Harddrive
SOURCE: My Asus G71G-A1 Notebook freezes on startup and makes short beeps
Have you tried entering the 'Safe Mode?'
By tapping either F5 or F8 right after power on, you will interrupt the normal (currently ABnormal) Windows boot path and see a menu that will let you enter a mode with a terrible scattered Desktop but only very few Windows functions installed.
One of the latter is probably bollixed.
If it worked OK in the last days, you may be able to use the saved (good) condition by reverting to it via the Restore routine.
You can start this by clicking on Start, then Run, then entering in the provided window:
rstrui.exe
then click on OK.
Just follow the simple directions.
This will not affect your recent (or past) work, it only restores settings and freshens files to a condition of an earlier point in time when things were good.
This won't always fix your problem if you have been invaded by some spiffy malware but it is a good place to start.
Let us know if this helped-
SOURCE: i have a eee asus laptop. I cannot startup the
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
SOURCE: windows 7 wireless drivers
If you can try Stephan's solution first.
If that does not work try looking at the actual manufacturer's web site for your wireless card. They may have them out before Asus does.
SOURCE: Webcam and touch pad not working.
do an update on drivers through the asus website or the brand of webcam/touch pad
Testimonial: "Thanks. This cleared up my problem very quickly!"
