LG 42LG50 42 in. LCD HDTV Logo
supermex Posted on Feb 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need some sound to my home theatre system
I have a coby dvd958 home theatre system and a 42LG50 lcd tv, I have one hdmi cable that runs only from the home theatre system to my tv. Sound and picture are great when watching dvd's, but I need to find out a way to watch regular tv and use my hometheatre system with sound, like to watch sports..Ive tried the digital coaxial hookup, nothing..tried old way av inputs...nothing..Our area is still mostly analog , I hook regular coaxial to the back of my tv...Not hooked up with any digital packages, just standard cable. I thought that by using that hdmi cable, it would take care of everything...NOT..Any solutions or ideas?
  • 4 more comments
  •  supermex
    supermex Feb 05, 2009
    I ve tried the audio input ports as stated in the manual...no sound..if I try using someo other audio ports on the back of the tv..i get LOUD...sound that cannot be controlled from the tv or the HT..It just blasts...so, I cant use that...As far as input selected...I don't recall there being any special input on the tv to select...Ive been told that not having a digital line coming in could be my problem. In looking at my Coby manual..all it says is this...."use a coaxial cable to connect the coaxial output of this unit to the coaxial input of the power amplifier". and it gives you a picture..duh...Also in the Digital audion setup: I have 3 options...1. is Spdif/off: there will be no digital audio signal output(coaxial off) 2.ALL: the digital audio signal output will be in its raw format 3. The Digital audio signal output will be in PCM format.
    LPCM OUtPUT: When digital output is set to pcm only, this item is available. Select a sampling rating for the analog audio output. there are two options, 48KHz and 96 KHz...NOTE: Some amps don't support 96khz sampling which will affect the coaxial output...
    ENOugh said, SO..i have my settings on ALL.....frankly i don't understand any of that stuff...that is the way the whole manual is...dolby digital setup this....prologic that..........I ve always hooked all of my own electronics up....now its getting to be over my head a bit......Any more help????
  •  supermex
    Again, I do not see any special input that should be selected on either the tv or the coby ht.
  •  supermex
    supermex Feb 06, 2009
    Ok...jhall1793...when you say use the correct digital audio cable..are you talking about the digital coaxial cable? The end has an orange ring around it...So, I take that as being correct..as far as the HT system itself..I received it as a gift from work....So, I got for nothing actually.....But, what ive seen on the internet is that the systems are much to be desired, alot of little problems...Ok..as far the manual...I can email you the pdf file that I have, if you would like? I just need an email to send to..or is there another way?..I don't have a scanner anymore, so I just email everything.....Let me know..I will not be doing anything with the system until Saturday sometime..Iam seriously thinking about looking into another system down the line...Thanks again........[email protected]
  •  supermex
    supermex Feb 12, 2009
    jhall, sent you an email.........I will try to get the ht done this friday or saturday...thanks.............
  •  supermex
    supermex Feb 14, 2009
    One more problem, any way of eliminating or reducing the hissing in my surround sound speakers when they are not in use?..I can hear a little bit of sound from them, but too distorted...When playing a dvd, they work great when needed...It just gets annoying..
  • Anonymous Mar 31, 2014
    im trying to hook the cable up and cant get it off digital mode and I want it on analog mode
Anonymous
Level 2:
Scholar:
  • Expert 60 Answers
  • Posted on Feb 04, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
60
Questions
0
Helped
31409
Points
140
Hey gr37_98:
1 thing to keep in mind with HT (home theater) systems is that when selecting a particular function that the input to the receiver matches the output to the TV/monitor. Example, you can play dvd's just fine because the HDMI output from the 958 matches the input to your monitor. Many consumers are under the mistaken impression that the home theater receiver can convert the HDMI to some other format, i.e. digital co-ax or optical. This is not the case. To use some other input the receiving device must have the same function & that particular input must be selected in order for the receiver to amplify it.
That being said, when you previously tried the digital co-ax connection did you specially select that input on your HT receiver? If you didn't, the receiver would be expecting to be processing audio from the HDMI input & would ignore the digital co-ax. You may also need to select that output on the monitor in order to active it, which, in most cases, would be odd. I was attempting to access the owners' manuals for these units & decided to respond with basic info hoping to get you up & running. Respond to this post if you have any additional questions.
peace-out
  • 1 more comment
  • Anonymous Feb 05, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    dude:
    I wrote a
    long post & it got lost on this site. they have their posting issues. I'll
    try to make this short.
    1.You
    have digital broadcast available from your local tv station. ignore whoever is
    telling you otherwise.
    2. ignore
    the other posting. you won't have true SS (surround sound) using the analog RCA
    jacks.
    3. don't
    confuse the terminology. the antenna coax connector is not the same as the
    digital coax audio connector. plus it doesn't help that the chinese don't translate
    to english very well.
    4. make
    sure you're using the correct digital audio cable. the connector insulator
    should be orange. if it's not, buy the correct cable.
    5. on the
    HT, select option 3 & 48Khz for the digital audio. also while we sort this
    out, try turning off the tv spkrs to minimize the chance of over-driving them.
    6. you're
    not going to like this next part. your coby is not the best system or mfr on
    the planet. they don't recognize that system anymore. can't even find a users
    guide. can you scan & forward the users guide to me? it would help. i
    advise people not buy from places like home depot for equipment like this. and
    i advise them to buy from retailers with clear return policies to avoid issues
    like this. i also advise against buying dvd/combo systems like this one as well
    because it limits your options for upgrading & if the dvd portion fails
    then you're out of luck.
    get back
    to me & we'll keep flogging at it.
    peace-out
  • Anonymous Feb 07, 2009
    dude:
    Having access to the coby manual makes all the difference. The digital coax connection on the coby is an OUTPUT, not an input. So unfortunately the only choice you have left is to use the analog audio RCA jacks on the tv & the coby. Do the following:
    1. On the back of the TV connect to the audio output RCA jacks match the colors of your audio cable. Refer to pg 10 item #8 & pg #47 of the LG manual for the correct jacks.
    2. Connect the other end of that audio cable to the coby using Line 1 input. Refer to pg 6 item #2.
    On to the set-up. For now I'll be refering to the coby manual. Refer to pg #9 for these 2 steps. On the coby access the audio set-up pg. Find the analog audio set-up, downmix & select the "5.1" option. Next go to digital audio set-up, digital output section & select "all". what this has to do with the next step is puzzeling.
    Now refer to pg #11. Still under the audio set-up menu, go to the 3D processing pg & under the PRO LOGIC II section select "on". Aways leaving it on is your best bet over-all. These next few steps are set for personal listening tastes. Play around with different selections to see which you like best or as the source changes. "Auto" would probably be a good place to start. The manual explains the differences of the options. Notice that "panorama", "dimension" or "center width" are only available when the mode is set to "music". The reverb mode is fun to play with. I wouldn't concern myself with HDCD option & it's attendent filter option, unless you have any HD CD's on hand.
    Now refer to the LG manual pg #88 thru 100 for the audio set-up. Pg #93 tells how to turns off the TV speakers. The 1 thing that the LG manual doesn't mention is whether the audio output from the TV is fixed or is variable. Here's how to find out. start out with the LG & coby volumes set to minimums. after following the above steps, tune to a local tv channel, then slightly turn-up the volumes on bothe device until you hear the audio. then try increasing the only LG's volume to see if the coby's volume increases. if it doesn't then the output is fixed & you control the volume only with coby. if it does increase then set the volume on the coby for a comfortable max level & control it with volume on the LG. That should be it. As you alluded to in an earlier post this stuff is over most people's heads. the digital age is great but it adds complexity that most don't grasp or want to deal with.
    Please follow-up. If all goes well then please give me a favorable rating.
    peace-out
  • Anonymous Feb 11, 2009
    gr37_98:
    is the problem solved or not? The 1 thing I didn't mentioned in my last post was selecting audio 1 when listening to the TV. Please follw-up w/ your status.
    peace-out
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
15997
Points
51
Just need some sound to my home theatre system - 2feb827.jpgrun red and white composite audio cables from the audio out ports above the AVin1 ports on the back of the tv to one of the audio input ports on the home theater system, remember which input port you connected it to and when you want to watch tv with the home theater sound just switch to that input on the home theater system.
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
5helpful
2answers
How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
1helpful
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
I'm trying to get the xbox working through the home theatre system but I'm still getting the sound from the TV which has intergrated freeview. The Xbox is connected to the TV using an HDMI cable, the home...
you need to hook up the xbox' audio cables to the home theatre systems AUX in port and then have your system set on AUX, and you can leave your xbox' hdmi plugged into the tv, just be sure your on the correct AV chanel.
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
2answers
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
