SOURCE: LED Bulb Replacement
I've been searching for two days for the bulb replacement in my mother's 9110 sewing machine...needs a 240mW led lamp which the manual says 'not user replaceable'. I called the 800 # for Euro-Pro and the recording referred me to 1-800-361-4639 for Euro-Pro sewing machines. The rep I spoke with knew immediately the lamp needed (must get a lot of calls for this). The total cost including shipping was $31.90 and is shipped from CA. She said it is 2-4 wk delivery, but could come in as little as 2 days. I just ordered it today, so hopefully I will receive it soon and it will be what I need...it looks simple enough to replace, so don't know why they say it isn't user replaceable.
SOURCE: I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
SOURCE: Euro-Pro Model 9110 Monogram
are you sure that is the correct model #?
Check out http://www.euro-pro.com they have
has all the information including a downloadable manuals(pdf file)for most of their products
SOURCE: euro pro 9110 sewing machine doesn't work
The direct number to Euro-Pro's sewing machine phone reps is 1-800-361-4639. I've read of other people calling and Euro-Pro sends the parts they need (no charge).
SOURCE: won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
