The stroller handles are too short for my tall husband. Are there handle extensions available so he does not have to hunch while pushing the stroller?
SOURCE: how do i lock the stroller when closed/collapsed.
It will depend on which model you have. If you have the older version, then there will be a nylon strap (usually found around the bag at the back of the chassis) this strap has a black plastic snap lock on that will go around the handle bar when closed and keep it closed.
If you have the newer version, this will automatically lock shut via a grey plastic clip on the side of the chassis.
I hope this helps.
SOURCE: handles
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
I hope this was helpful, DutchTexan
SOURCE: Link between handles needs replacing. Are parts
This is called the "hand grip connection bar". Your dealer should be able to get this part for you. Please ask for part number SPQ465230.
It is also available on our website. Please follow this link:
http://www.babycare.nl/quinny-zapp-hand-grip-connection-bar-p-2094.html
Please note that the connection bar is attached by rivets. Before trying this yourself, please make sure you have the proper tools. If not, mounting the part is best done through your dealer.
I hope this helps.
Erwin de Raad
www.babycare.nl
SOURCE: I slammed my stroller handle bar in my trunk. It
Look at this website www.vintagepramfan.com and I am sure if you post a comment they will advise.
