Goldstar DH504EL Dehumidifier Logo
A
Anonymous Posted on Feb 06, 2013
GE TFH27PRSM refrigerator wiring diagram - Goldstar DH504EL Dehumidifier
2answers
I have an old Sahara 25 dehumidifier need water collector chamber
I contacted GE on the web and found out they don't make the parts anymore for this unit. I used Gorilla glue to repair the cracks in the old semi soft plastic water collector chamber.
dmbrownpe
The coils on my dehumidifier are frosting over.
Are the coils clean? If it has a filter is it clean? If yes to both, it has lost (leaked) refrigerant and it's time to buy a new dehumidifier. If the leak can be found it probably wouldn't be repairable and would cost more to fix than it's worth.
1helpful
What terminal on the capacitor gets the blue wire from the run terminal on the compressor? Does it go in the terminal with the white wire or the blue wire?
Follow the start wire from the compressor to the capacitor, the run wire will go to the opposite side.
For instance if the white wire is the start wire on your compressor then the run wire will go to blue wire and vice versa.
2answers
Tripping BreakerS
Same problem as both above. Humidifier trips after maybe 5 minutes. Top of machine is very warm; there's no on/off switch, so plugging in does nothing until the heat dissapates. What's the solution, to just buy a new piece of equipment?
Location of Maytag M7DH45B2A motor fuse
I'm fixing one of these too. Take the top off (follow the AC cord) and the fuse is on the PCB.
I am also looking for a better wiring diagram - the control panel on mine does not light up.
2answers
I have a GE Dehumidifier, Model # AHK40LKG1, Serial # AM166016. Thus far we have used the bucket to empty it. We now want to use the hose attachment to empty it. I find that I have the clear plastic tube...
I have same problem (ie, missing this drain nozzle). From my searching, the GE part number is : WK09X10006.
Found it on : http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
searching for 'drain nozzle'.
My searching (so far) is finding a couple places online to purchase this, but at $14-$15. Still looking for a better (ie, cheaper!) option.
Hope this helps.
Top Goldstar Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
