Question about KitchenAid Kitchen Aid KP26M1X 6 Quart Professional 600 Series Mixer
Kitchenaid mixer 600 won't turn on
My wife was mixing bread, seemed to overheat and stop working. Won't turn on. Smoke came up after it stopped, not a lot, but enough that I'm pretty sure the motor is burned up.
  • daniel_bo941
    daniel_bo941 Feb 09, 2013
    Looks like it just overheated, works fine now.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Posted on Feb 08, 2013
4 Suggested Answers
SOURCE:
  • 13 Answers
SOURCE: kitchenaid mixer 45ss
I dont know much about them but If you cannot get it repaired I do have a lift bowl stand mixer that I bought without the bowl or attachments that I would sell for $80.00 Or I will buy your attachments. Thanks, Mark.
Posted on Mar 23, 2009
  • 145 Answers
SOURCE: professional 600 - makes loud noise when
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Posted on Jul 08, 2009
  • 145 Answers
SOURCE: Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
I have an old kitchenaid K5-A mixer that I inherited from my grandmother. It has been working fine until recently. When my wife turned it on to mix up some cookie dough, the engine started to smoke. I...
well Kevin your mixer is indeed old and the parts for it are most likely no longer available. I would first visually inspect and wiring in the unit. if this seems okay, it could be that your field winding is gone or the worm gear inside that drives the unit is simply burnt out. hope this helps.
Thanks
Oct 01, 2009 | KitchenAid Food Mixers
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
Jun 24, 2009 | KitchenAid Food Mixers
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Overloaded Motor
Are you mixing at a high speed. For bread, you shouldn't go above a '2' setting on most of the mixers and keep the time fairly short -- more isn't needed.
Sorry if this is redundant, but info posted to another problem works here as well:
KitchenAid has one of the best user forums of any company as far as I'm concerned. The participants are great and the monitors are exceptional (some of the best problem solvers you are likely to run across). You may find your experience already has a thread, if not, post it. I checked in and they seem to have added a video library that has some of the topics I've seen posted at this site.
http://www.kitchenaidconversations.com/
Oct 29, 2007 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid Kitchen Aid KP26M1X 6 Quart Professional 600 Series Mixer Logo
521 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
