SOURCE: show on the screen to reattach output bin. and i
You say you have opened and closed the cover, your error appears to be related to the output bin assy on the left of the printer. Remove and reininstall the output bin assy.
SOURCE: re attach output bin error swaped known
Look for the sensor that is tripped when the output bin is attached. Trace the wiring back to origination. Either sensor is bad or wiring is bad.
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
