Upper and lower ovens preheat and hold temperature 50 to 100 degrees higher than set temp. even if I open the oven door to cool off the oven , the temp will rise to above set temp. We have tried two seperate oven thermometers and both read high.
SOURCE: 5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
SOURCE: Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
SOURCE: I have a Jenn Air
This is a control board / unit problem with these models. It is not an easy repair really, but if you are extremely handy it can be done. Let me know if you want to try the repair yourself and I can find the part.
Thanks
Tim
SOURCE: oven is 50 degrees out of calibration and will not
Hello, kadid
I was trying to help
you out here. Maybe this will help some? I was going back to some customers that asked questions
in the recent past and farther back, It appeared that no one answered some of them, So, I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your oven, from repair
to trouble shooting it. Even pictures and video's. Just scroll around
and you
will see tons of information to almost any question you might have on
your Oven. If you go to this link and click around, I am sure you
will find out so much about your oven, you will know more than the
company that made it. The good thing about this link is, then you can
make the decision of DIY or hiring a pro. Here Is the link for you to
click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
SOURCE: Hello, I have a Jenn-Air W131W, double wall ovens
Hello, weejay
and you
click on>>
Thanks,Mike
Thanks,Mike
no fault codes were set. how is control panel temp correction made at panel?
