An electric shaver is a grooming device designed for shaving facial or body hair using mechanical blades driven by an electric motor. It typically consists of a set of oscillating or rotating blades enclosed behind a perforated metal foil or comb. The motor-powered blades move rapidly, capturing and cutting the hair that enters the perforations. Electric shavers are known for their convenience and efficiency, as they eliminate the need for water or shaving cream. They come in both foil and rotary designs, catering to different preferences, and are suitable for various hair types. Electric shavers are popular for providing a quick and comfortable shave, making them a common choice for individuals seeking a time-saving and modern grooming solution.
A razor is a bladed tool primarily used in the removal of unwanted body hair through the act of shaving. Kinds of razors include straight razors,disposable razor and electric razors. Electric razors are best for shaving your hairs quickly and smoothly than manual shaving machines.
Not like shaving razors, electric shavers work by shearing
the whiskers, the hair enters the perforated metal heads of the shaver and is
cut by the moving blade inside.
When you use an electric shaver
you can shave either with or against the growth of your hair. In case you use a
rotary shaver, you should make small circular motions with the shaver head on
your face, do I gently, let the shaver do the work for you. If you have to
press down hard in order for the shaver to cut your shaver is dirty and needs
to be cleaned.
