First you need to strop the razor on a daily basis, you
should also horn your edge every once in a while. Moreover, you need to prevent
corrosion from forming on your razor. In order to do so, you would need to
rinse your razor after each use and allow it to dry properly. You should also
keep the blade well lubricated after each shaving session.
All razors lose their edge over time even with daily
stropping. Honing reestablishes the fine edge of the razor by removing some of
the medal some of the metal from the razor. Honing is a necessity when it comes
to razors.
The temper of the razor is the heat treatment imparted to the blade during its manufacture. Razors can be either hard, medium or soft temper each with its own benefits.
The balance of the straight razor refers to the relative weight and length of the blade as compared with the handle. A straight razor is properly balanced when the weight of the blade is equal to that of the handle.
The key things you need to consider when you buy a straight razor are its balance, its temper, the size of the blade, its grind, the finish of the razor and its style.
The one big advantage of the straight razor is that if you take care of it properly it can last for a long time unlike modern razors which you simply throw away after a few shaves when they come too dull to use.
The straight razor handle usually made of hard rubber, plastic, bone and even metal.
A straight razor is a shaving razor constructed of a long
steel blade attached to a handle by means of a pivot. A straight razor is a
classic shaving method and nowadays it is less commonly used since the
invention of the safety razors.
