My touch pad won't work on my laptop.. Is there any troubleshooting for this problem?
Step 1:
Touchpad Not Working in Laptop b> Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
You didn't supply the Asus model, try Asus Support : http://support.asus.com/ServiceHome.aspx?SLanguage=en
SOURCE: Touch Pad mouse not working
Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
SOURCE: touch pad not working in HP laptop
Try checking if it has been disabled.
Select Start > Control Panel > Printers and Other Hardware > Mouse
Please don't forget to rate this solution.
SOURCE: How do I unlock my touchpad on my new Emachine
There should be a button just above the touchpad to reactivate it. If not, it will be the Fn key + one of the Function buttons at the top which look like a touchpad icon.
SOURCE: I spilled coffee on my Dell Inspiron 1545 laptop,
You might be able to find a cheap replacement palm rest (which includes the touch pad) on E-Bay or similar site. Just search your model number.
As far as replacing it yourself, I recommend having someone that works on computers regularly doing it, unless you are completely comfortable working inside the laptop. If you are (and you take all necessary precautions), here is the Service Manual from Dell which includes disassembly instructions for the palm rest.
http://support.dell.com/support/edocs/systems/ins1545/en/SM/index.htm
Testimonial: "This was much better information than I expected to receive."
SOURCE: I have an Asus K60 Laptop.I can not figure out how
Did you try the FN key and F9...
That is what they say to disable your touchpad
You have a function key which is called Fn That key allows you to use the functions on the F series keys
So Fn then F9 should do the trick
Testimonial: "Awesome! THATNK YOU!"
The keyboard takes a lot of abuse and as durable as it is, they will eventually wear out. It is a very inexpensive part to replace and does not require a lot of skill. The fact that the touch pad is acting up could indicate that they are interconnected. I would replace both. The Touch pad is a more involved part to replace and I would suggest you get some help or pay to have it replaced.
You can order them off of sites like eBay, then watch a YouTube video on how to do it.
I punched in:
ASUS Eee keyboard and got several results like:
ASUS Eee touch pad:
These are ramdomly selected:
