How can I hook up my DVD player to my Proscan 32 inch LCD TV.
I have RED, WHITE, and YELLOW but no picture.
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Does your TV has same red-white and yellow input pins? If yes, hook cable as per color and select proper input of TV by remote, play dvd player and enjoy.
Please check what input number is at TV pins where you put leads of red-white and yellow. Now select that specific input by tv remote.
Make sure put yellow to yellow, red to red and white to white in player and TV.
If every this is set as above, There is no reason of "no signal" display on TV.
There are 3 known video connecting cables for TV and DVD Players.
Yellow-Red-White calls Composite Video (yellow wire) and red and white for L and R sound channels.
Another is S-Video, it is special connector cable having 4 pins in round connector. red and white for sound also used with it.
Component Video is new thing with Red-Blue-Green pins for video and red-white for audio, so total 5 wires used.
Now you need to look at rear or player and TV for appropriate hook up. Important thing is to select proper AV input in TV to view dvd player picture.
how do you do the proper input. i have tried everything on the TV
Thank You for your response but I try that and I still do not see or hear anything except "NO SIGNAL"
I did that and made sure the red white and yellow went to the same color but again I get a "NO SIGNAL" and I even tried all the different input selections. Now I bought a proscan LCD TV and there are many different places where I can put the different color wires, maybe I need different cables.
Please advise.
Thanks for your help
